Perform this procedure to view the entity aliases on the switch.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Entity.
  3. Select the Alias tab.
Alias Field Descriptions
Use the data in the following table to use the Alias tab.
Name
Description
Index
The index of the entry
LogicalIndexOrZero
The index of the entry. The value of this object identifies the logical entity that defines the naming scope for the associated instance of the Mapping Identifier object.
This is always 0.
MappingIdentifier
The value of this object identifies a particular conceptual row associated with the indicated Physical Index and Logical Index pair.
Because only physical ports are modeled in this table, only entries that represent interfaces or ports are allowed. If an ifEntry exists on behalf of a particular physical port, then this object should identify the associated ifEntry.
This is the OID of ifIndex.Port.
